Thank you very much. Wanted to make sure before I bought the tool.
This tool (JDG1641) can be made at home or your shop,
JDG 1641 Clutch removal tool workaround
One each - 1/2-12tpi x 6.0" long Grade 8 bolt (Course or fine threads... It doesn't matter)
One each - 9/16-18tpi x 4.0” long Grade 8 bolt
Cut the threads and hex head from the 1/2" bolt leaving just the shank of approximately 3.37" long. Make both cuts square to prevent side loads during removal.
Put the 1/2" shank into the hole first. Lube the 9/16-18 threads (I used anti-seize) and crank away.
Please use only Grade 8 bolts for this workaround tool
