1 - 2 of 2 Posts
Does anyone know the torque spec for the main clutch on a 2008 Gator TX ?
If so, is there a special procedure ie: High torque to press the clutch on then loosen and re-torque for service ?
I'm not intimately familiar with the TX, but I expect that it is on a tapered shaft as are the other models. The right size bolt and shank will remove it and the retaining bolt just needs to be tightened to the normal torque setting for that size bolt. You can find torque tables on line.
Hope this helps
1 - 2 of 2 Posts
