101 - 107 of 107 Posts
If you've read the forum for a while you've probably seen member MBDiagMan offer his clutch tuning services. I took him up on it and sent my clutch to him. I got it back last week and WOW! what a improvement. This is the best a clutch has ever worked. It works better than a "good" clutch fresh from the dealer.
I have not had a single instance yet where the clutch did not open as it should. Previously hot days and getting the clutch hot would cause problems. I gave it every torture I could this weekend and every time I stopped the clutch disengaged perfectly.
A benefit I did not expect is that it shifts more smoothly. I never thought I would be able to feel it but it does noticeably shift/transition more smoothly than before. Previously when accelerating I could feel that the clutch was balking as it up and downshifted. Now it's a continuous, butter smooth progression when accelerating and decelerating.
Aside from the clutch operating properly. It is just more predictable. After driving it a while I know exactly when it's going to engage and disengage. Previously there a range of where I thought it would do something. Now it does it like clockwork at the same rpm every time. It's doubly amazing considering how hot I got it and it still is predictable and reliable.
Can you get him to contact me about tuning 550 clutch, [email protected]
I had to take out my transmission to replace shifter and some shims fall on the mounting bolts where do they go and why??
