21 - 38 of 38 Posts
I mounted the motor at the bottom, motor side towards the passenger shock... just to keep it away from the motor! I purchased a few sleeves as spacers to make up.the difference n the size of the bolt holes
Do you have an 825i? It has a gas shock lift assist? Smaller brackets on the middle of the bed and wider brackets on the frame?
When I did the install, i raised the bed a the way up... and raised the actuator to the top bracket! Bolted it up, lowered it a little bit and sharpied a line so I know where to stop, so i wont over extend anything!
Yes, I shortened everything... the limiter switch rod, interior shaft, exterior casing, and even shortened the wires so they would fit inside better
I'm having the same issue! Maybe a small homemade bracket?
We started to make a new bed for my friends because it had previously been used to spread salt at a mall (there practically was no bed anymore) but we used the old brackets to make the new bed. If you have the old one that is. Otherwise forget this post lol
21 - 38 of 38 Posts
