I'm new here to the site and have a question for you guys and gals. I recently received my 2013 825i the other day. I bought it with the poly roof, glass front windshield, and poly rear panel with a sliding window. I use my gator to check irrigation wells so I do a lot of driving on gravel roads. After driving it for a few days I noticed that the dust is pretty bad inside the cab. I can tell that the dust gets sucked in and hangs there. I was wondering if I would take off the rear panel, if that would solve my problem or make it worse. Does anyone else have this issue and if so how did you fix it?
Cab Dust
I had the same issue driving gravel roads or spraying fence rows in dry conditions. Switched to a half windshield, a roof and back panel. Now the air flows over my head, down the back and out the sides. No dirt in the cab.
you have lower air pressure inside causing dusty air to be drawn in. what I did is remove the front shield during the dusty months. I have tried several things prior to removing the windshield but none worked very good. channeled air in through a large vent-failed,cut air vents in the roof-failed. most of the fixes require speed to make them work. (lots of air flow)my speeds were under 10mph.
I pulled the shield off in aug and put it on in sept.
jim
I take the wind shield off when the temps start to warm up outside. It makes for a more comfortable ride! Sometime in November the windshield goes back on for the cold weather.
