I have a 2012 Gator 825I with eps....I went to an automotive class yesterday evening a CTI class and the topic was eps..My Question is How are you guys doing with you eps systems and any Failures?...Found out if the alignment is off eps the motor will run more,,,Hence the motor will run more keeping the vehicle going straight down the road..Quicker for a Failure...I Found out and realisticly did not Know much about THIS!!! take your Gator to the Dealer and Have them 0 The steering angle sensor { SES} then the motor wont run all the time...It was a Cool Class..learned Alot
