I took charge of a XUV835M that has been out of service for about six months due to a dead battery. I replaced the battery today and started it up and received this warning light. I cannot find the meaning in our manual
Red - power steering issue. Check to make certain all wire junctions are clean to bare metal and tight. Looking at a connection isn’t going to do it. Requires disassembly and cleaning with wire brush or sandpaper. A better test is to use a voltage drop test to ensure power and ground circuits are capable of carrying load.
In the operators manual under the controls section there will be a sub section for the display and all the symbols... I made a video on my YouTube Channel on how to pop codes from the ICC display on an X300 series lawn tractor a couple months back... I may have to make another video on how to retrieve codes on one of these style displays as a future video idea...
Update - I parked the Gator a couple of hours to cool off. Then the problem went away. I'd been spraying in some heavy weeds and brush higher that the Gator, so the power steering must have overheated. I went back and had no more problem.
If the red and amber indicators are displayed then it means the ESC is disabled and the code needs to be read in order to point you in the correct direction of where to proceed and start troubleshooting... This is where the manual is handy...
I don't speak french... Maybe one of our Canadian members can help this one... I'm guessing he's asking about power steering...
Related Threads
John Deere Gator Forums
posts
59K
members
19K
Since
2011
