1 - 2 of 2 Posts
Hello,
I have a T520 Gator and it has a reoccurring issue.
when i attempt to stop/slow down by taking my foot of the accelerator the engine doesn't disengage and tries to power forward- usually ends up stalling when the foot break goes on or occasionally calms down, it is not always an issue as it comes and goes- but when your in front of a lake, wall or tree you need to stop!
- i believe it could be a damaged gear box?? which isn't allowing the gears to disengage?
Thanks
That's definitely a possibility.
Is it returning to idle OK or are the RPM's staying up. Remember the primary works on Engine RPM and centrifugal forces, so if too high it won't allow the clutch to return to full open (disengaged).
Post back what you find.
1 - 2 of 2 Posts
