I have a MFWD angle drive gear box for a XUV550 Gator. I had a gear box that I rebuilt with new bearings and gears with little run time on it and a new set of cases. I took the gears and bearings and installed them in the new cases. The output seal and the shifter o-ring have been replaced. The back lash for the gears has been set to specs. If you look at the pic you will see that there are two small 6mm bolts in the outer case cover. I drilled and tapped the hole to let the air escape out of the gear case when the transmission is being filled. The passage way for the oil to go through is super small and the air in the case has to go through the same holes to let the oil in. By removing the screws while filling the transmission you can make sure that all the sections of the cases are filled. The PN is MIA881848 and list for $983.16. I'm asking $150 Plus shipping. Please PM me if you have any questions. I still have this gear box, someone make me an offer. I have more pics of the gear box disassembled. They are resized and won't attach. I can e-mail them to you.
Mike ...Nice work as always !
