6x4 elec info
ok, even though no one may need help anymore, I'll throw some more info out there just in case. I found some elec diagrams for what looks like '93-98 6x4 diesel gators. key position in run, first click, you should get dash lights indicating power and probably everything electrical is good. key position turned to start, it starts and why are you reading this
? it cranks slowly....check battery/connections....nothing....again check battery/connections/start relay/fuses or fusible links. starts but doesn't stay running....check ignition switch in run position, this keeps power to locking relay after ignition, or clogged fuel/air filters/oil pressure switch....OIL
.....for some excellent customer service finding a local supplier/manuals try JD Parts.com or
[email protected]
