gator 6x4 diesel newbie
1 reading
4K views 13 replies 4 participants last post by  6555SM
#1 ·
Hi all im new to this forum stuff so please excuse me if i make any mistakes in etiquette ,
i have a 6x4 gator diesel circa 2002-2006 ish
it has lost all power to the ignition lights and show no signs of life except the head lights ,
does anybody know of any fuses other than the ones under steering wheel ?
or can anybody point me in the right direction to solve this ?
many thanks in advance
stu
#2 ·
stu
Welcome Stu
Do you by chance have a copy of the Operators Manual for your Gator?
If not here is link for a 6x4 Gator Operators Manual:
http://manuals.deere.com/cceomview/OMM154861_A9/Output/Index.html?tM=HO
After reviewing the manual I don’t believe there is a second fuse panel on this model.
I have inserted a couple screenshots below from the Operators Manual that may help?
I have also sent you a PM with a link to a OEM Technical Manual that may help you as well.
Please keep us updated on your repair.
Good luck!!
#10 ·
....one thing is that the purple wire that sends pulse too starter from the back of ignition switch goes to earth when keyed , it does not send a positive electrical pulse ??....
I believe this is the correct condition for the switch to go to ground to create a spark
#7 ·
Great suggestion CaptSeabee,
Look here for the fusible link:
#9 ·
PM sent
#11 ·
Have you tested the neutral start switch?
#13 ·
Well folks after a busy week it still seems to be working , so hey ho onwards until the next issue , thanks for all your help lads
stu
Great news, what was your solution?
