1 - 9 of 9 Posts
I have a rectangle headlight 6x4 gator that won't crank when the key is turned to start. I have been able to get it to turn over by hitting the starter relay and it will crank. I have tried another relay with the same results, is it possible it's not getting enough power to close the relay contacts? Does anyone have a wiring diagram for this relay? Thanks
Discussion Starter · #2 ·
It's looking like the switched power wire is corroded somewhere. I am only getting 11.5v at the yellow wire without the diode when the key is on and 12.5v at the red wire on the relay. I jumped a wire from the yellow to the red and it starts by the key, so the relay is good, just need to find where that wire is bad.
Do a voltage drop test along the conductor while under load and it will be obvious where the issue is.
I had forgotten to unhook my jumper and went back out and the battery was dead. Charged the battery and it's working now but there is about .5V drop in that yellow wire from the key to the relay.
Break the circuit down and measure voltage drop at each junction.
Example: put meter lead on Crimp terminal and the other on the wire. With the circuit energized it should be zero. Repeat along the circuit - wire end to wire end, wire to crimp terminal, crimp terminal to post, etc… ideally the voltage drop is zero. May need to use the mV scale.
0.5 volt drop is a lot.
Reactions: Bradhill
This may be academic to you guys that are mechanics, but I put a $25 Starter Improvement Relay that I bought on eBay that solved my no-crank problem on my old gator.
Please start a new thread, your question might be overlooked.
1 - 9 of 9 Posts
