The dipstick on the transaxle is also the fill plug. The oil in the trans axle normally stays the same as new oil. Plug is located at top rear of transaxle.
The oil in the engine turns black with more running time. This is due to the carbon buildup during operation that occurs when engine is running. Watch the oil level closely on the engine oil dipstick.
The oil leak is most likely from the engine
Check oil filter to make sure it is not leaking at the base
Check oil psi sending unit
Remove skid plate from beneath the engine to get a better look at where the oil is leaking.
Sent from my SM-N950U using Tapatalk
