I have a 2013 gator 825I. It has died and will not start. It tries to start when I crank it over but will not continue to run. The fuel pump does not cycle like it usually does when I turn on the key. I have checked the fuses and they are fine. It will crank over fine but will not start. It appears to be a wiring problem or lack of the fuel pump not cycling correctly.
