You didn't say if you had a 4x2 or 6x4 because there is two separate sections. This primer is from the 6x4 section. It would be handy if you had the entire tech manual. The whole PDF thumb includes parts and owners manuals as well. A real bargain at twenty five bucks plus shipping.
John Deere Gator Utility Vehicles 4×2. John Deere Gator Utility Vehicles 4×6. on any device with a reader such as Adobe. Manual Contents Manual is a duplicate of the original to serve as a spare copy to preserve the original.
www.ebay.com
I have no financial interest in this.
Electrical Operation and Diagnostics - 6X4 Gas - 289
ELECTRICAL OPERATION AND DIAGNOSTICS - 6X4 GAS
Troubleshooting - 6X4 Gas
System: Electrical
(1) Does starter have cranking problems?
Yes - See “Power Circuit Diagnosis - 6X4 Gas” on page 292.
Yes - See “Cranking Circuit Diagnosis - 6X4 Gas” on page 296.
Yes - See “Ground Circuit Tests” on page 396.
Yes - See “Battery Test” on page 372.
(2) Does engine crank but not start?
Yes - See “Ignition Circuit Diagnosis - 6X4 Gas” on page 299.
(3) Is there spark from the ignition?
(4) Is the fuel pump operating?
(5) Does the engine not shut off?
Yes - Check for a shorted circuit.
(6) Is an improper component working with a switch?
(7) Is there a problem with the engine oil light?
Yes - See “Indicator Lights Circuit Diagnosis - 6X4 Gas” on page 307.
(8) Does the battery go dead, discharge, or over charge?
Yes - See “Charging Circuit Diagnosis - 6X4 Gas” on page 303.
(9) Is there a discharge light problem?
(10) Are there cooling fan problems?
(11) Are there instrumentation light problems?
(12) Are there light and horn problems?
Yes - See “Road Homologated Light and Horn Circuit Diagnosis” on page 493 or “Light and Horn Circuit Diagnosis (Earlier Model)” on page 447 or “Light and Horn Circuit Diagnosis (Later Model)” on page 468.
(13) Are there domestic headlight problems?
Yes - See “Standard Headlight Circuit Diagnosis - 6X4 Gas” on page 312.
(14) Are there cargo box lift problems?
Yes - See “Cargo Box Lift System Troubleshooting Chart” on page 405 and “Cargo Box Lift Circuit Diagnosis” on page 406. System: Electrical
