I purchased a used 2009 Gator 620i a few days ago. While in a forward gear (low or high) traveling up an incline - if I let off the accelerator while still in forward gear and without pressing the brake - the unit rolls backward as if it was in neutral. Also, with the unit in gear while turned off - I can easily push it forward and backward.
Is this common or do I have a potential problem?
Pretty sure its normal for your gator. My RSX does that, the CVT belt goes loose/neutral if the engine is not spinning the clutch. Just the way the trans work in these things. Its not like a cars wet clutch transmission.
X3 on it being normal.
Welcome to the forum!!!!!
