Engine and Electrical
- Type 4-cycle gas, Electronic Fuel Injection (EFI) -
- Closed Loop System
- Cylinders/Valving V-Twin, OHV
- Horsepower* 62 (46.2 kw)
- Displacement 839 cc
- Maximum torque 57.5 (42.4 ft lbs) @ 4000 rpm
- Cooling system Liquid
- Battery 340 CCA
- Alternator 38 amp @ 7250 rpm,13.5V - regulated
Lights
- Headlights Four 27 watt halogen
On-demand true 4WD system
- Front Differential Selectable Limited Slip and Full locking
- Rear Differential Locked (full-time)
Transmission Type
- Enclosed and sealed Continuously Variable
- Transmission (CVT)
- Ground speed, mph (km/h) 0-53 (0-85) Hi Forward, 0-30 (0-48) Lo
- Forward, 0-15 (0-24) Reverse
- Transaxle Two speed, oil bath
- Front/Rear Brakes Front/rear hydraulic disk
- Park brake Foot brake; mechanical actuation
- Wheel Bearings Sealed, double-row ball
Suspension and Steering
- Front Suspension Independent; double A-arm with coil over
- shocks & anti-sway bar
- Front Suspension Travel 9in. (229mm)
- Rear Suspension Independent; Semi-trailing double A-arm
- with coil over shocks & anti-sway bar
- Rear Suspension Travel 9in. (229mm)
- Turning radius 19.7 ft. (6.0 m)
Hitches
- Front and Rear Optional 2-in receiver (front)
- Standard 2-in receiver (rear)
Roll-Over Protective Structure (ROPS)
- Tubular overhead structure 1.75 in (44.4 mm) steel tube
- Seat belts 3-point seat belts
- Certification ISO 3471 and OSHA ROPS
Ground Clearance
- Ground Clearance Front 10.3 in. (26.2 cm)
- Under Foot Platform 10.3 in. (26.2 cm)
Dimensions
- Length 119 in. (302)
- Width 56.5 (143.5)
- Front/Rear-tread Centers 48in. (1220mm)/46 in. (1170mm)
- Height (with OPS) 72 in. (183mm)
- Wheelbase 77.8 (1975mm)
- Weight (dry), lb. (kg) 1360 lb (617 kg)
- Towing Capacity 1200 lb. (544 kg)
- Payload Capacity 800 lb. (363kg)
- Seating Capacity 2
Cargo Box
- Material Composite
- Dimensions, in. (mm) 32.3L x 47.6W x 11.7D (82cm L x 120.9cm W
- x 29.7cm D)
- Volume 8.9 cu. ft. (0.25)
- Weight 400 lb. (181 kg)
- Dump 2-sided - Manual release
- Tailgate 1 handed release; Hinged at bottom; Removeable without tools
Tires, Front / Rear
- Maxxis Big Horn 2.0, Radial 26x8-14/26x10-14 (w/alloys) optional on base
- Ancla MT (Mud Terrain) 25x8-12/25x10-12 (w/ steel)
- Terrahawk AT (All Terrain) n/a
Color
- Options Green/Yellow
- Olive/Black
- Camo
Storage
- Front Sealed oversized Glove Box, Under hood
- storage 1.82 ft3 (0.052m3)
