1 - 20 of 60 Posts
Hello.
I Am hoping to find some help! we sold are 825i gator.
Then in a couple days the guy said it wouldn't shift anymore so he
brought it back, now the only way to get it to shift is to open the bed and hammer on the
shift lever coming out of the transmission. I talked to are local dealer and a said to put wd40 on the shaft
coming out of the transmision and wiggle it back and forth, but that doesn't help:( then I took the bolt and little plate
holding that shaft in place and pulled the shaft out about a inch and it turns freely! if you have any suggestion on how to fix this would
be greatly appreciated!!
If you plane on fixing yourself, you might want to consider purchasing the workshop manual.
Inside on this shaft there are two spring pins (one inside the other) and a shift fork. Perhaps these pins or the fork broke.
I'm guessing you'll have to disassemble to investigate.
You might want to search the forum as I vaguely remember someone having a similar problem.
Report back what you find.
Is the shift lever hard to get into and out of gear?
Yes, the shift lever will move a little bit but wont go
into gear. So you have to go to the back and hammer on it hard!
I am hoping to do this myself unless it gets to complicated.
Might try to get the transmision out today the see what I find. thanks for your replies so far!
Have you cleaned your primary and secondary clutch’s ?
No they have not been cleaned.
but will check into that and see if thats an issue. hopefuly thats all it is!
PM sent - I will send you information on cleaning procedures.
What yr or serial number , just seeing if higher serial number if inner bearing on drive clutch ok letting clutch return to shift.
Discussion Starter #19
Finally got the transmission out!!
either will take it to are local dealer or doing it myself depends on how hard the fix is.
1 - 20 of 60 Posts
