Glow plugs shot on the diesel XUV. Wow! How do you replace them? They are under what looks like the engine head or valve assembly. The tek manual does not have a section on replacement other then how they work and the electrical drawings.
Already confirmed glow plugs bad. Only one workingtake a closer look at the electrical diagram, something upsteam of the glowplugs is a more likely problem, glowplug relay? any fuses? poor wire connection? weak battery/connections? verify with a meter before jumping to a conclusion. I'm not sure, but I assume your gator should still crank but may be hard to start in the cold temps if ALL the glow plugs were failed.
Thanks for posting the NGK number for the plugs.If it helps I just replaced the three glow plugs NGK Y1021J on my 2011 Yanmar diesel gator. All three were blown.
Glad to hear you're up and running.... It started first turn of the key from cold.
