We bought a Gator XUV590E S4 last year, mostly for use out at the acreage. It's 12' long, 1700lb. and the only trailer of ours that could handle it was the Aluma car hauler. Thats a bit of a pain, being long, low, wide & having pull out ramps. So we did some browsing of inventory near by & the wife decided she liked a red Texas Bragg 14' 7K utility at the same place we bought a dump trailer a while back. Deck is 2" timber, 76" across. 2' high sides with expanded metal & pipe top rail. 4' high- ramp built of 2 inch square tube. Electric brakes on only one axle, I'll be adding brakes to the idler axle as it already has a brake flange, waiting for the etrailer house brand 10" self adjuster to get back in stock.
These are pics of our trailer while on the lot (same trailer, VIN's match)
Finally, pics of the S4 on the trailer. Good clearance on the approach angle with the truck air suspension in high position, marginal clearance on the approach angle with the truck air suspension in lowest position (per an observer). Of course this could also be changed by changing the ball position on the hitch. No deflection of gate components observed during load/unload. I had no problem moving along between gator & trailer side when I got out. .
I'll be installing 3/8" D rings front, back & sides tomorrow, I picked up a bunch of grade 8 bolts at tractor supply today.
14' is just enough room for it.
