Grinding Gears
7.9K views 6 replies 6 participants last post by  Rlclayton6X4
Diagnose and fix the problem before you do any more damage to the transmission.
If you turn the engine off does it shift into gear OK? If so that can indicate that the primary clutch is not releasing and is still trying to turn the transmission. In most cases this is caused by the primary clutch (the one on the engine) not fully opening. You can also open the machine up so you can watch the clutches in operation. With a helper you can drive and watch the clutches or if working by yourself you can securely block the back wheels off the ground so you can operate the machine without it moving. Sometimes you will see the primary clutch open to point when at idle. The it will open the last bit after shutting the engine off. This is a very good indication that the clutch needs work.
