hello
diesel 855 xuv has a hard start in the mroning and temperature is only at minus 4 or -3. i do leave glow plugs on for roughly 20 seconds. any suggestions please??
GP may not be working. GP's are on a timer based on coolant temperature, so not certain how you leave them on for 20 seconds when operator has no control over the on-time.
Suggest you thoroughly check the GP wiring circuit for the root cause.
when i turn key theres a icon assuming its the glow plugs then it dissapears after 20 sec
Time should vary with temp, but sounds like you're following the general procedure.
I'd verify full power is reaching the glow plugs and that the GP's are functioning correctly by measuring their resistance.
