My 2008 Gator TH 6x4 diesel quit on me. No power and can't raise the bed so I need to take it off to figure out why it quit running. I have been trying to remove the pin that connects the actuator to the bed and it's not budging. Same problem with the lower pin. Any ideas on how to get it out? Thanks in advance for any help.
I'd figure out how to get power to it and get the bed up, couple jumper wires from the battery ought to do, pull the connector and power up. Once up then pull the pin and let the box back against the tires, gives you plenty of room.
Good, I had problems with the electric actuator with the bed stuck up, had the bumper up against the trailer hitch and to much pressure to do anything, wouldn't go up or down and the pin was way to tight, thought the lift was locked up. Finally had to cut the hitch and the darn thing starting working....go figure...never knew you could get enough pressure to stop function in the opposite direction.
