1 - 8 of 8 Posts
it could be pushing air from the belt housing and with the summer heat that could be where it is coming from
Pushing air
I have had several other machines. This is the first to do this. It is 95 degrees outside and hot air us blowing on me. The Deere dealer said it isn't normal. I better get it in before warranty is over
yea thats a first iv never seen one push air out of the belt housing from the intake. id get it to the dealer and let them take a look for sure
so the cooling fan was the problem?
Complaint or Symptom :
Radiator fan blows hot air into operator’s station around the operators legs.
Problem or Situation :
Open areas in the fire wall allow hot air from the radiator to blow onto the operator and passenger’s legs.
Solution :
Order and install AM144752 Seal kit.
Additional Information :
- Verify the under hood storage compartment (M163638) is installed which limits the hot air entering the operator’s station.
- Vent the windshield and rear window (if equipped) to increase airflow through operator’s station.
- Remove cab doors (if equipped) for warm weather operation.
1 - 8 of 8 Posts
