1 - 1 of 1 Posts
I really hope someone had had this issue. I have a tech working on it, and we are both baffled.
You try to start the machine, and it won't start. You pull either plug, and leave it out of the cylinder, it will fire right up, and idle perfect. I haven't tried to put a load on it while the plug is out, but I am going to see if it will move under power. Any clues as to what my issue is? Already checked valves, new plugs, crank case seems to be pushing out air, yet not a ton, oil is new, filter is new, carb has been gone through. Appreciate any help someone might have.
1 - 1 of 1 Posts
