Had to reset the clock due to day light savings time. Noticed that there is an outside temperature in the system but it does not show up on the instrument display. Have found a posting that JD uses a module on the Gator that is used on other equipment for it's outside temperature. It does not work however on the Gator. Am I wrong or is there a fix to get the outside temperature displayed on the information center. There is a blank box between RPM and clock which would be a good place for the outside temperature.
