1 - 14 of 14 Posts
Folks, I know this forum is all about things gator. But maybe someone has experience with a Buck? It's one tough son-of-a-gun and has served me well for MANY years. I've never done anything but change engine oil/filters/batteries. It just goes and goes. But I'm getting concerned about the front differential. It has started to "yowl" in reverse. I have no idea of the lube required - I'm sure its way past time to change it out.
Advice? Lube type?
Thx, JRH
Follow this link to find you operators manual. I'm certain it will contain the information about lube type and amount you seek.
JD Manual Lookup
Advice: Provide better service to your equipment over the years 馃榾
JD Manual Lookup
I have the original Ops manual. In the maintenance section for service intervals anything other than the most simple of simple tasks state "Dealer Service Required" or something to the same. As for Lubrication nothing is specified for the differentials.
Over all the years it still has just less than 100 hours on it. The seals are tight without any signs of seepage. Overall its had just transportation duty. It has the power and gearing of much more but its over all weight is less than adequate for safety. It's just a low speed, light load work-a-holic with a solid rear axle, swing-arm suspension. I've always loved the geared automatic/manual xmission.
Guess I'll have to find and buy the danged shop manual.
Here's what I found in the manual... :unsure:
Liquid Types and Capacities
Liquids
Oil type (engine and transmission) (10W40 Summer) (10W30 Winter) SAE, 4-stroke mineral-based engine oil.
API classification SG, SH or SJ. Refer to OIL VISCOSITY CHART for proper grade.
Coolant Ethylene-glycol/water mix (50% coolant, 50% water). Use coolant specifically designed for aluminum engines
Fuel type Regular unleaded gasoline
Fuel octane 87 (R + M)/2 or higher
Differential (front and rear) 75W90 or 80W90 (API GL-5)
Hydraulic brake Brake fluid, DOT 4
Propeller shaft joint grease SAE Multi-Purpose Moly Grease
Cable Lubricant Silicone Spray Lube
Suspension Grease Multi-Purpose HD Lithium Complex Grease
Brake Fluid DOT 4 Brake Fluid
Capacities
Fuel tank 22 L including 4 L reserve (5.8 U.S. gal including 1.1 gal reserve)
Engine/transmission oil oil change with filter 3.0 L (3.17 qt)
Coolant 2.5 L (2.65 qt)
Differential (front) 610 ml (21 U. S. oz)
Differential (rear) 200 ml (7 U.S. oz)
Brake Fluid 250 ml (8.5 oz)
Liquids
Mr 200mph, Thank you sincerely. It's not in my OEM manual but no matter - I will absolve my lack of maintenance sins tomorrow. I just happened to have a case of gear lube for everything else ready for this small project. If the lube comes out nasty I'll submit myself for a threshing.
The Buck gets more use now. The Land Cruiser in the background has yet another sheared front axle. Sigh. Use a tractor when a tractor is justified. A Land Cruiser is not a tractor. It wouldn't be problem except for a gov-locker in the front. The axles just can't handle a locker in low range.
No problem. The info was in the owners manual provided using the link posted earlier.
Good luck with everything!!!
Advice? Lube type?
Thx, JRH
Here is a link to the Operators Manual for the Buck 500.
Look at the index on left hand side under 鈥淪pecifications鈥 from there you should have all the information you requested.
Discussion Starter #10
Yeah, yeah. You are right. Back in another era this Buck 500 got much more use. But where we are now the 6x4 gets much more use. I mainly use the Buck when I don't need to carry anything which is rare. I do have a 'lil plastic JD dump trailer but the past the gate is very rough and ancient logging trail(s). The trailer tends to empty itself regardless of speed :-(.
So, here is another question: The grease zirks on this Buck are straight. There is no way for a std coupler to hold on so greasing the front end is messy. In addition, several of these zirks are in places that a right angle coupler is needed. I haven't found a coupler for this style of zirk - let alone a right angle coupler. These zirks do not have a hex so it leads me to believe they were pressed in and not threaded.
The 6x4 has standard zirks.... Any ideas?
BTW 200mph, thanks for the specs sent previously.
.......So, here is another question: The grease zirks on this Buck are straight. There is no way for a std coupler to hold on so greasing the front end is messy. In addition, several of these zirks are in places that a right angle coupler is needed. I haven't found a coupler for this style of zirk - let alone a right angle coupler....
Check out Lock n Lube for grease gun couplings, these couplings make servicing your grease fittings so much easier. They also have 90 degree couplings for those pesky right angle zirks.
If you should ever need parts look at Power Sports Nation in Norfolk Nebraska they鈥檙e a large used part warehouse for UTV鈥檚. I noticed they have a fairly large assortment of used parts for the Buck.
Discussion Starter #12
What a pain! I got into the rear differential for the oil change and removed the drain plug. Then I went to remove the fill plug and its half way covered by a frame rail - ya can't remove it without disassembling the swing arm. That's just crazy. I drilled a hole in the top of the differential without anything getting into the case. I'm pondering the plug now - a self threading 5/16 without shavings maybe. But really, this is crazy for service. It's not JD, it's Bombardier's design. It's a cool rig but....
BTW, the drain oil came out clean++. I was impressed.
Discussion Starter #13
I've been pondering the differential plug from the hole I drilled in the housing from atop. I actually think an old valve stem is perfect. Its tapered so it can't fall into the case. I'm thinking to just cut the cap screw section off and insert a machine screw with a wing nut through and tighten it up. It will expand and seal. Before, silicone the screw so it can't fall out into the differential.
Has anyone gone through this in times passed?
Discussion Starter #14
That cant work with a valve stem. I need to fashion a plug but with something that can't fall into the differential. At this point I'm thinking about a well placed blob of RTV over the 5/16 hole and feather it out and keeping an eye on it.
1 - 14 of 14 Posts
