hello everyone I desperately need some help solving an issue with my gator. I have the kawasaki fd620d engine in mine that I done pistons rings and new cam shaft in all was well with build and has 165ish on compression after rebuild. but the issue I'm having is its dieseling once it's up to operating temp. can't make it do it at all when it's cold. when I turn it off after it's up to temp it runs for a few seconds before it finally chokes out. I have done what I know to do on the Governor assembly. put high octane gas in it. and adjusted the carb to the best of my knowledge. I'm pretty sure the timing was dead on when I was going back together with it but was wondering what else it may be? I did install a new cam and cam gear and did not change the tappets or the push rods or valves. didn't figure I needed to since it already had a steel gear cam when tore down. please help!! and thanks in advance.
