The gear shift lever is not engaging to allow the starter to kick in, all that happens is a click toward the back of the engine
Have you checked and cleaned all connections?
Check your battery ,clean connections and load test . Making sure you have enough amperage and volts . Also check the positive clamp real good and cable gets corroded .
