John Deere updates Gator UTV
6K views 10 replies 6 participants last post by  clearplumber
#1 ·
John Deere announces the model year 2016 RSX860i, replacing the previous model RSX850i. The RSX860i provides enhanced performance and ease of operation for Gator customers. Updated features, including a new power steering option and backlit toggle switches, improve manageability of the utility vehicle without compromising performance. Changes to increase speed, add power steering and increase warranty were made with the consumer in mind, and are based on customer feedback and market-driven research.
“Every adjustment and addition made to the RSX860i comes as result of our team actively listening to customer feedback,” said Mark Davey, John Deere marketing manager, Gator utility vehicles. “Top speed was one of the priorities we considered with these updates and we were able to increase the maximum speed to 60 mph (97 kph).”
The maximum engine speed increased from 7250 rpm to 7750 rpm, allowing the RSX860i a 10 percent increase in top speed over the previous model.
Electric Power Assist Steering (EPAS) is now an option on the 2016 model. The anti-kickback feature reduces the amount of unwinding steering when operating through demanding terrain. The system also senses speed and adjusts steering effort as the speed of the vehicle changes for improved terrain feel and maneuverability.
All EPAS equipped vehicles are pre-wired for a winch. Utility vehicles with the winch-ready chassis greatly reduce the winch install time. The winch components that are pre-installed include a wiring harness, a negative battery cable and a disconnect wiring harness.
For ease of operation during early morning/late evening, factory-installed toggle switches are now backlit for easy identification. For reduced noise, the front differential is a spiral bevel design. The helical design of this gear set is stronger and produces less vibration and noise compared to the straight cut gears found on many competitive vehicles. The steering knuckles and control arms are also painted post-machining to prevent rust and discoloration for a long lasting aesthetic appearance.
The RSX860i comes with a 12 month or 1,000 hour factory warranty, double that of many competitive recreational vehicles. The machine can also be ordered in traditional John Deere green and yellow or Realtree Hardwoods HD Camouflage.
The Gator RSX860i High Performance Utility Vehicle is now available for order and will arrive at John Deere dealers in mid-July.
See less See more
1
#3 ·
Is there any kind of up date or fix for the fuse box on pass. Side of the 850 where the charging fuse gets hot an melts
#5 ·
i hope so i had said something to the Deere reps before but who knows what they will do
#6 ·
What exactly is the problem with the electical? I have heard several things about over heating and melting of electrical components on the RSX. Does Deere know what the problem is? How have you fixed it?
Sent from my SM-N900P using Tapatalk
#7 · (Edited)
yea i fixed mine and i have wrote them about the problem and told some reps before. the problem is they fuse holder on the passenger side has no protection on the back side where the wires go into the block. so what happens is when the gator gets hot and water hits the radiator some way the steam vents up well it also vents along the frame and side of the hood. the steam eventually finds its way through the fuse holder and melts the fuses. then u will start seeing charging problems. i had to replace the whole block assembly but used silicon as a backing to help with the problem. that was over a year ago and i havent had to replace a fuse yet.
#9 ·
It seems that would be a big issue if you were 50 miles down a trail.. I wonder why Deere hasnt thought it was a big deal to fix.
#10 ·
it can be matthew i was 15 out on a trail in SC when it first happened to me. i was also 4hrs from the house. not how i wanted that trip to go. iv riden it hard and doubt checked everything and its still good and its the factory parts just added silicone to the back.
