1 - 9 of 9 Posts
I have a xuv590is4 and when I put it in 4 wd it’ll jump out of 4wd, then in and out. If I put it in 4wd diff lock it stays in 4wd. Is there a cable adjustment and a spec? Thanks for the help in advance
Ok guess this doesn’t work so well
Yes, there likely is an adjustment however that information is in the Technical Manual which is copyrighted by Deere. Folks may be a little queasy about openly sharing that protected information. Suggest you pick up a copy of the manual check eBay
Reactions: [email protected]
Thanks. I was just hoping someone else had the same thing and was willing to share.
You might use the “ Search Community “ function to see what others have done, if you haven’t checked already ?
What did you find in the search?
Did you try the suggestions and they didn’t work?
Solutions never reported?
I had my 550 apart years ago so I had to reinstall all the cables. It was a pretty simple matter to adjust everything without the manual. I was able to move the levers on top of the transmission and differential and feel where it should be for each mode and adjusted accordingly.
1 - 9 of 9 Posts
