Where ca I get parts for my Kawasaki FD620D-KS11 engine it came out of a 1998 6X4 gator
Right now I need Flywheel magnets front and rear case bearings gasket kit since the motor is compleatly disassembled probably rings also do you know if the cylinders can be bored out I live close to Pittsburgh PA
I ordered from Amazon and ebay, found full gasket kits and the crankshaft bushings you're needing. Don't know about oversize pistons. I just honed my cylinders and put new rings in.
Sent from my SM-N960U using Tapatalk
While you're in there, you'd do well to check the timing gear. If it's the original plastic version, replace it with the new metal one. The plastic ones have a typical life span of about 800 hours.
