1 - 10 of 10 Posts
29.5/30
I was running 29.5s on stock wheels with no lift for a while. The only time it had any problems was when it bottomed out. I know of another guy some where running 30" silverbacks with no lift and another guy around here running 30" Intercos.
Tire size
For the people running the 28" tires, was there any rubbing on the shocks? My 2014 RSX850iSE has about a half inch clearance between the 26" Big Horns and the Fox 2.0 shocks. I just ordered a set of 28" Big Horns and plan to make a shock adjustment to get some additional ground clearance. Will I need to buy wheel spacers for the bigger tires? if so, where can I order a set of wheel spacers for the Gator?
i have 30s and ran it with no lift for months. i did go with 10s all the way around instead of a skinny wide set up. there was slight scrubbing when turning but only if i hit a bump. have a super atv kit on now and love it.
Thanks for the info on mounting 30" tires on a stock Gator. I will let you know how the new 28" tires and shock adjustment work. I need to get some more ground clearance. On our first ride with the stock set up, it bottomed out and rubbed the skid plate a lot.
yea i had the same problem with mine the 30s helped alot but the 2 in lift did the trick
How does the Super ATV Kit work? Is it a lift for the front n just adjust the rear shocks up? Or is it a lift all the way around at all 4 corners? Wanting to run the 28x10x14 Outback Max tires on my stock rims. Thanks
The Superatv lift has a bracket lift for the front two shocks and uses a Puck style to lift the back but if you would prefer a bracket lift for the rear then Josh makes one. He is a member on here. You will have no problems with the 28s like i said i ran 30s on mine and it did fine
1 - 10 of 10 Posts
