1 - 2 of 2 Posts
Have a 625i, the motor idles great and accelerate’s fine. The engine seems to intermittently miss at low RPM(above idle). Again it tops out fine and seems to have decent power. When I say miss It doesn’t pop or after fire. It doesn’t quit, it’s as if the throttle is being let up without command, does anyone have any ideas?
poor fuel quality... ? i would drain some out into a clear container and see if you have water contamination..it is easily seen if you let it set for half an hour so..
1 - 2 of 2 Posts
