Finally got the big gun duals installed. Man its sounds sweet!
I was thinking about that too. Supposedly the kit from snorkel youratv is designed so as to produce the same airflow that it gets from the stock intake by that logic you'd just assume it wouldn't be any different from stock when running exhaust.I am not running the controller and everything is stock except the exhaust. I wonder if you will have to run it with snorkels?
That's another thing I was thinking also after reading that on there site.I was thinking about that too. Supposedly the kit from snorkel youratv is designed so as to produce the same airflow that it gets from the stock intake by that logic you'd just assume it wouldn't be any different from stock when running exhaust.I am not running the controller and everything is stock except the exhaust. I wonder if you will have to run it with snorkels?
