O.K. Here are the details on the XUV 550 and XUV 550 S4. It will be available Nov-Dec this year.
The XUV 550 Crossover Series Utility Vehicles are powered by a 570-cm3, V-twin gasoline engine. The carburetor is tuned for rapid throttle response, reliable cold-weather starting, smooth mid-range power delivery and quiet idling.
The engine offers the following performance and reliability features:
- 16 hp* at 3600 rpm
- Tuned to deliver 0- to 15-mph acceleration in 3.2 sec.
- 28-mph (45-km/h) top speed
- Dynamically tuned carburetor for rapid throttle response upon demand while allowing the engine to burn clean under light loads.
- V-twin, 90-degree overhead valve design maximizes power and torque and provides longer valve life
- Designed for cold-weather starting (tested to -20 degree F)
- Full-pressure lubrication system
- Spin-on oil filter with drain bracket and oil drain valve enable easy servicing
- High air-flow air filter
- Utilizes nano fiber technology to increase the efficiency of the filtration without sacrificing horsepower
- Laminated and contoured engine blower housing cuts noise levels while reducing oil temperatures 25-30 degrees
- T6 heat-treated aluminum alloy connecting rods and piston ring package
- 200 Watt (16 max A) charging system for accessory capability
- Exhaust system design
- Dual header pipe to muffler maximizes airflow and provides a unique V-twin sound
- Spark-arresting muffler is USFS approved
- Low fuel consumption and large 4.9-U.S. gal. (18.9-L) fuel tank
- Environmental Protection Agency (EPA) and California Air Resources Board (CARB) compliant
* The engine horsepower information is provided by the engine manufacturer to be used for comparison purposes only. The actual operating horsepower will be less
