ignition issues
Filet......I replaced the ignition switch (key on dash) ,but still had same issues.....my son-in-law came over and we got to looking and moving wires around , and found a lose wire the went to the little grounding block ( a little metal box thing about 1in x 1in x 1/4in , mounted about 4in towards the front from the spark plug on my Kawasaki eng) the wire was in a connector but just had a couple wires left and with the wiggling it broke lose......re stripped the wire and reinserted and then re crimped the connector .....we have used the gator 6 or 8 times since this week and all start and stops work as designed
all the problems and it ended up just a loose , bad crimped wire
hope this Helps .....check all the wires and all the connectors......a friend had mud dobbers short out his ATV , they built a nest (clod) on a relay on the frame , when it was humid it would not run , when it was dry it worked (he's allergic to bee's and stuff so was afraid to mess with nest) so had a neighbor bust up the clod and it works OK now , he sprayed with WD40 to keep them off electrical stuff......
