I have a leak that is coming from the oil drain on the bottom of the 625i. Just a drip on occasion. I tightened the oil drain with a 10 mm wrench and turned the whole drain assymbly going into the engine about an 1/8 of a turn. Is this a threaded drain assymbly that could have some oil compatible silicone put on the threads to stop the drip. It is coming from this area, just not sure if the assymbly can be removed to add silicone or not.
Mark
Mark
