1 - 2 of 2 Posts
hello, the info I posted already is the 0NLY info on the frame, there is a barcode sticker on the side of the frame but it has no #'s beneath it. If it's any help the neutral safety switch is mounted underneath the shift lever. I bought TM 1518 online and it is not the correct one for this machine. By the way the barcode sticker has the same info as is on the frame. As before any help will be appreciated! Thanks again!
Well i tried to look up information based on what you posted and that's not enough letters/numbers. It's important to know the year and/or the full serial number to determine what Tech Manual you need.
1 - 2 of 2 Posts
