After delivery and in the woods.....We took it up today with a trimmer, chain saw, and limb cutters to clear out the old logging road..then it started to rain..
In the garage...
Angle shots
CV Joint shields...
Chery motor
Tail light guards
the dumper...no power assist
air cleaner with inlet nipple
more CV joint shields..dealer left plastic ones in place
ready for a winch and something to fill those holes
Under the hood with storage tray (fairly flimsy no secure attachment...just gravity) in place. The wiring harness seemed to prevent it from sitting properly. Radiator and brake reservoir
Under the storage tray.. area where JD winch solenoid mounts
Accessory fuses attach to a frame member,, I assume asscessories are the 12V ports on dash and console
Circuit box. includes a tie wrap around box
Battery under passenger's seat. The spec sheet says 340CA but battery is 450CA / 45 AH
Windshield motor and Switch box for rear lights*
Rear pointing work lights
Instrument panel
CV joint shields again
Lower shields..access to oil filer
In the garage...
Angle shots
CV Joint shields...
Chery motor
Tail light guards
Instrument panel
