Hello and thank you ahead of time for any replies We currently have a 850d the issue we are experiencing is intermittent start issue just clicks and blows the reset-able fuse we put in please to replace the stock one (fuses like that are to come by) We replacing the starter I was lucky to find one but still same issue. any ideas would be great or if someone has a book for it that would be handy as well. This thing is our lifeblood moving around the fob
Welcome to the forum Afghan_Deere!!!!!!!!!!!!!! Someone will chime in to help!!!!
Most of the time the fuse blows means there is a short to ground which could be in the wiring harness or starter having internal short which draws to much amperage. Using a amp draw gauge will determine that. Don't rule out a bad battery also that has a shorted cell and while starting it can draw to much amperage also. Just some suggestions That I have ran into.
