The parking brake on our 625i no longer holds. We have checked the oil inside the brake as required and it is good. What else could the problem be?
Check to see higher serial number units you can adjust the cable near the hand lever, should see the cable and jam nuts . if you adjust and still have 12 clicks of the lever ,your brake disc in the assemble on burnt and worn, you can remove and rebuild it or replace it. remember to fill back up with oil to plug.
