Actually, I'm not sure if my oil level wasn't low from the factory as I've added over three quarts and was still low according to the indicator on the stick. BUT I did measure what I got out of the machine and it was a little over 3 quarts which is more than what most are reporting here. I did let it drain for several minutes while doing other things and had it on a Jack, raising/lowering it until there was no more oil draining out. That could have been a contributing factor as well..
The 28" zillas seem to fit like a charm with no adjustments after a short ride around the neighborhood power line. I have way too much air in them from being mounted. They rattle the doors, my teeth, for etc. lol. I know it's the air as there is no squat or flex even when hitting the curb. I have the same exact tire on my Honda Rancher and run them with very little pressure as they ride better and seem to perform Better at lower pressures. Just worried about losing a bead on the gator w low pressure.
