1 - 12 of 12 Posts
You are welcome- did you have a chance to click on the link? if not - you will find schematics for all your part numbers. It does pay to shop around for parts.
Lindsey541,
Please confirm "M0HX0PA012182" is the correct number. I could not find anything that starts with M0HX. Most HPX 4x2 and 4x4 start with M0HP and this was the closest sequence I could find.
I'm not saying that it is wrong. Just couldn't find a listing in the info I have that contains the number referenced above.
Please post back.
Can you help me find the year this gator 4x2 is ???? View attachment 14821
Welcome
If you are curious as to the DOM of your Gator, look under John Deere Gator Forums, click on the first discussion area What Year Is My Gator.
From here you will see a thread titled -Model Year Lookup Table- look for your PIN. If your PIN is not there see your dealership.
There are several online Deere part warehouses such as Green Farm Parts use code GTT for discount and Green Part Store use code TTWT for free shipping. These online companies can often provide better pricing than local dealerships.
Additionally, please check out @SuperATV for aftermarket accessories for your Gator link below:
SuperATV
Manuals
Additionally please use the robust “Search Community” function on the forum, there is a great deal of information available through this function.
Thank you, Enjoy your Gator !
That’s all the ID you need and what is needed to get the correct parts.
See first post in the General section if you want more.
There really isn’t much to be learned from the number otherwise.
there is no VIN. The number you posted is the unique identifier.
Reactions: tode0118
1 - 12 of 12 Posts
