RSX 850I I don't really understand the clutch system but when I go down hill the compression helps to slow down, then invariably it pops into neutral and I start to rocket down hill.
I was told to tap the accelerator to get it to go back into compression slow down. That works for about 1/2 second and pops back into neutral and the rocket ride starts . Does this need an adjustment? Also, the gas peddle is not smooth, I barely touch it and it jumps like a racehorse at the gate...Adjustment?
