Two people with the same issue means it’s normal 😂.
What does your owners manual suggest the light means?
My guess based on the limited info provided in these posts… Bad ground or loose connection. Loose meaning electrical current path is disruptive. It’s possible to have tight connections and not able to conduct due to corrosion. That’s why using a voltmeter surpasses the common visual test.
