I think this is now called a "Turf Gator", is that correct?
Just before winter my Gator developed an oil leak...after some experimentation it seems to be coming from the gasket where the clutch comes out of the driver side of the engine. When I parked it I was able to get it into reverse gear VERY slowly, but it wouldn't move in forward....I'm pretty sure the belt is soaked with oil.
At any rate now that we have warm weather again I began tackling this issue. I got the clutch off and now just have the shaft coming out of the engine (pics attached I hope).
From the look of things I'll need to take off that portion of the engine that's there where the shaft goes into the block? I assume the gasket is seated from the inside? That's what would make sense to me given oil pressures anyway.
Any suggestions/guidance here would be appreciated. If somebody has a part number that would also be awesome of course, otherwise I'll ping the John Deere people. I understand this model is older so I might have to substitute, but I'll cross that bridge when I get to it.
Thank you!
Steven in Colorado
Thank you!
Steven in Colorado
