Afriend gave me a 2003 diesel 6x4 that caught on fire in the engine compartment and melted a section of the wiring and fuel lines on the passenger rail. I have installed a new wiring harness but I need help with the part numbers of the 4 relays ( 2 on the right rail behind the passenger's seat and the 2 at the rear of the engine compartment. Thanks in advance for any help you can give me.) 20201206_153158.jpg 20201206_153132.jpg 20201206_153048.jpg
Perhaps look up the part numbers on jdparts.com.
Google the PN's and you're likely to find specific information about the relay. They're likely to be a generic 30A or 40A relay.
Once the form factor and current ratings are determined, I'd consider using waterproof relays and ones with diodes or resistors to reduce the potential harm when the magnetic coil is deenergized. Usually these options don't add much to the cost and will still be under the crazy price JD demands for a commodity item.
