Hi everyone new to the site from Texas. Just got an older 6x4 gator (gas) for a song. I want to eliminate
all of the fusible links and replace with a 12v 12 position fuse block. The question I have is what is the current
on the solenoid so I can fuse it?
Any help is GREATLY appreciated
You can edit posts by selecting the 3 vertical dots in the upper right hand corner of the message block. There should be an edit function there.
Sorry I don't have the information you solenoid current draw you're looking for.
The solenoid is essentially just a relay, so the draw should only be an amp or so. Your best bet would be to measure the current draw with an ammeter, then fuse it for about double the measurement
Thanks for the info on the edit function.
