My rsx 850i will not start. Light cluster comes on but fuel pump does not kick in at all. Look at connections, fuses and all appears good. Any ideas
Without ever having worked on one of these.
Afaik the fuel pump should kick in no matter what but i have seen other john deere equipment that shuts off even the fuel pump when a safety switch does not work.
So thats something to check.
And yes get a testlight to check fuses because simply checking them by eye is not enough
Or ofcourse its a broken wire or bad connector somewhere.
Yes i have seen connectors that looked good but did not let any power go through.
Again: testlight
(Story:we had a new mechanic looking for an electric problem once.
Could not find the problem even though he checked everything.
Asked him Where his testlight was and he said he could work without and check all connectors and fuses.
Long story short i told him to get me a testlight ran it over the fuse panel 5 seconds and it simply had a burnt fuse.)
